Remote wire from HU to AMP
Username: Mwright1000
Post Number: 85
Can I use a #12 THHN copper stranded wire for my remote wire. I am planning on running 3 amps so I want to make sure it can handle them all. Thanks
Username: Carguy
Post Number: 5056
If you're going to hook up 2 or more devices on the same remote wire, get a 12v relay for $6.
The remote wire's max current is 200ma. Not enough power for multi amps.
The answer to your question is yes since it sends out very low current.
