Amp keeps kicking off
Bad_Azz_Bowtie
when i turn my stereo up about 3/4 way up sometimes less.. when the bass hits my amp will go to protect mode and will shut off.. anyone know how i can fix this.. i have a Massive audio 1500.1 amp. any help would be great thanx yall
Username: Rovin
Trinidad & T...
Post Number: 3712
only 2 reasons most amps shut off
1) wrong ohm load - ex a 1ohm load on a amp that can only go down to 2ohm
2) lack of power due 2 loose connection or amp calling 4 more power that your alt can't create current fast enough
Bad_Azz_Bowtie
would having a 150amp fuse where it is suppose to be a 100 amp fuse cause this to happen? like a power overload protect?
Username: Tjmutlow
Post Number: 361
no
