Unregistered guest | OK I have just recently started to build my own boxes and hey they are turning out great but, the boxes havent been for me. I have no system at the moment cause I sold it all cause it was crappy and now I'm looking for 2-12" or 2-15" subwoofers withing a 260-340 price range for a pair of woofers. Please tell me if this are any good and if not recomendations would be helpful. Thanks http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3166 or http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3168 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2463 Registered: Jul-05 | are u looking for sq or spl |
Gold Member Username: RovinTrinidad & T... Post Number: 3342 Registered: Jul-05 | I remember Glasswolf saying that he finds JBL subs are mediocre - not too good not too bad but middle of the road .... |
Bronze Member Username: Swishblank88Vashon Island, WA USA Post Number: 29 Registered: Oct-04 | is that budget just for the woofers? if it is I would go with these Perfects. I am a big infinity fan. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2932 these or a pair of alpine type "R"s off ebay...not to sound redundant. Depends on if you want SQ or SPL tho chauncey is right. If you can build a good ported box you could get some good SPL for that price. |
Unregistered guest | Holy Snap, Thats one mighty fine subwoofer ya got there. Ya know what I think I just might get them. Thank you for bringing that to my attention and by the way what kinda amp will do for 2 of those? |
Bronze Member Username: Swishblank88Vashon Island, WA USA Post Number: 33 Registered: Oct-04 | well they are about 350 rms a piece. they can easily handle 400 rms each though. Hmm what is your budget for an amp? |
Unregistered guest | well what I was think is that I could use my friends 1200w sony xplod temporarily to power them while I save up for a really good amp. so is this a plan or should I not use his amp. Well Im lookin for something that will put out 1000wrms-1200wrms , this is why i want to save up |
ReLOaDeD Unregistered guest | well what I was think is that I could use my friends 1200w sony xplod temporarily to power them while I save up for a really good amp. so is this a plan or should I not use his amp. Well Im lookin for something that will put out 1000wrms-1200wrms , this is why i want to save up |
Bronze Member Username: Swishblank88Vashon Island, WA USA Post Number: 35 Registered: Oct-04 | For about 200 bucks a Hifonics BX1205D might suit you good. It says it will put out 900 rms at 2 ohms, so if you wire your subs in parallel you should be set. Hifonics are a little overrated tho so your subs might see about 350-400 apiece, probably just what your looking for. Look on ebay and stuff, those amps are all over the place. |
Bronze Member Username: Swishblank88Vashon Island, WA USA Post Number: 36 Registered: Oct-04 | whats the model on that sony? and careful with anything sony, it probably puts out like 400-600 watts depending on the model which wont suit those infinitys too well. The hifonics are a middle of the road amp that are pretty reliable, especially if you have them at 2 ohms. That amp will probably put out close to 1000rms at 1 ohm if you change your set up later. But for a really nice amp look at the orion 1200d. It will put out pretty much what it says it will, I think its like 1200 @ 1 ohm, 750 @ 2 ohms, and like 400 something at 4 ohms. Since youl have 2 4 ohm subs you will be at like 750 or so, which is perfect for those subs. That amp is very good but also quite expensive. |
ReLOaDeD Unregistered guest | so nick, could I find one at a car audio shop and get that hifonics ordered at the $200 price, or will I have to get it online used? right now im lookin around locally for a powerful amp that I can get my hands on for around $200. SO please help me out, your doing a good job so far. I really need an amp |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2539 Registered: Jul-05 | If ur looking for powerful cheap, Hifonics, Cadence, and Audiobahn |
Silver Member Username: Islandboy808Mililani, Hawaii US Post Number: 162 Registered: Nov-05 | alpine type rs,thats what i have and they hit hard.u can probly get it on ebay for about 260 shipped.(thats for two type rs) |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 1152 Registered: Oct-05 | get the two type Rs with the hifonics bx1500d. it will sound nice and loud. |
New member Username: Alex_fLawrenceburg, Ky Us Post Number: 6 Registered: Nov-05 | hey reloaded, do you ever buy off ebay? |
Anonymous | homer man dude change that name - it sounds like H0M0 MAN ! no disrepect but ppl WILL give u hard time with that username . Unregister & come back as Alex F as it says in your profile . |
New member Username: Alex_fLawrenceburg, Ky Us Post Number: 8 Registered: Nov-05 | that acount got messed up, itried to change my email address and they suspended my acount. and then i count use alex farris anymore |
New member Username: Alex_fLawrenceburg, Ky Us Post Number: 9 Registered: Nov-05 | iv been trying to get it back |
Gold Member Username: RovinTrinidad & T... Post Number: 3415 Registered: Jul-05 | u will get alot of flak 4 it so just click on 'Your Account' above & change it ......... |
New member Username: Alex_fLawrenceburg, Ky Us Post Number: 10 Registered: Nov-05 | there |
New member Username: ReloadedMebane, NC U.S.A Post Number: 1 Registered: Dec-05 | Hey well would I be able to run that hifonics at ohms by wiring parallel to the subs juss like you said. that would give alot of power I need wouldnt it? |
Silver Member Username: Young_jamesCanada Post Number: 336 Registered: Sep-05 | Get Chauncey's Type X.........I think that will satisfy your needs |
