Can't you get the W6V2's in dual 2 ohm? Or are they only avaliable in dual 4 ohm? If you can get dual 2 ohm you can wire them in series and 3 of them will make a 1.33 ohm load that would be perfect for the 1200.1.
Thanks for the info. How or would it work 3 W6 the old ones and a 1\1000?
Just fine, you can go 4 ohm (series) or 1 ohm (parallel) with a trilogy of old W6's. The 1/1000 will support a load between 8 and 1 ohms so it will be fine, I would recommend the series wiring and run the amp at 4 ohm.
