Best amp for infinity speakers
Username: Safa19
Post Number: 128
whats the best 4 channel amp for infinity kappa speakers that puts out 100watts rms x4 at 4ohm im lookin around $200 or under
Username: Rovin
Trinidad & T...
Post Number: 2738
u will not get anything new for that 4 ,more like $300+ is needed unless u go ebay & get a used 1 .....
Username: Safa19
Post Number: 132
that sucks i wish speakers that are 40hm could be run at 2ohm
Username: Rovin
Trinidad & T...
Post Number: 2768
how many speakers u actually got ?
if u got 4 u can buy a 2chan amp (which are kinda cheap) & get a 2ohm load from 2 speakers on 1 channel but overal stereo sound will lack but it'll still power them fine .....
Username: Safa19
Post Number: 135
so i could get a 2 channel amp at 200watts x2 at 2 ohm and run 2 speakers per channel would that end up being 100watts per channel cause i do have 4 speakers
Username: Rovin
Trinidad & T...
Post Number: 2783
u got it !.......
Username: Fandim
Reno, Nevada United State...
Post Number: 447
You wouldnt end up losing stereo sound as long as you bridged the left speakers, and bridged the right.. (dont bridge front two, then back two..) This will let you keep stereo sound. :-)
Username: Rovin
Trinidad & T...
Post Number: 2786
yea i know - i should have further explained that to him ...Upload
Username: Safa19
Post Number: 145
so the orion 4002 would be good?
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 557
http://www.crutchfield.com/S-VdOOxOVXIO1/cgi-bin/ProdView.asp?g=120&I=575P4002
Orangevale, Ca. USA
Post Number: 558
Sometimes you can find that amp on ebay for about 240 shipped
Username: Safa19
Post Number: 147
yea but im going to get the orion 1200D for 2 type r's so i want to get the same brand amp for my speakers and its just a little over 200 on ebay
