Username: Aznegg Post Number: 21 Registered: Oct-05
Friday, November 25, 2005 - 04:11 GMT well... as the titel says... i need help choosing an amp.... I like the fact that the xenon amp is fan cooled, But i hear they are unreliable,and of poor build quality, but then i hear the opposite as well. Can someone dispell all the fog around these rumours... thank you very much!!
Alabama
U.S.
Post Number: 1979 Registered: Jul-05
Friday, November 25, 2005 - 04:32 GMT ok amp, whats ur budget, and we can help u find something of equal or lesser value.lol
Username: Aznegg Post Number: 22 Registered: Oct-05
Friday, November 25, 2005 - 06:15 GMT i have a budget of about 400 ish... shipped to my house.
Alabama
U.S.
Post Number: 2001 Registered: Jul-05
Friday, November 25, 2005 - 07:08 GMT re 12.1 Kicker kx 1200.1 Orion 1200d all 3 are much better then the pg
Username: Aznegg Post Number: 23 Registered: Oct-05
Friday, November 25, 2005 - 10:28 GMT How much would the RE 12.1 be because i was thinking about a 15" sx ..... is there a way to buy right from RE...? Also, what kind of damping factor doesthe 12.1 have i looked on their site and it didnt say anything.
Username: Mikechec9 Http://www.cardomain.c...
Post Number: 1642 Registered: May-05
Friday, November 25, 2005 - 10:50 GMT xenons are a good buy. i would snag it while you can as they are being discontinued. the newer lines are bound to be uglier. damping factot doesn't matter. you won't be able to tell an audible difference over 30. most are 100-300. but no, i don't have any of the 12.1 specs. call re.
Username: Rovin Trinidad & T...
Post Number: 2985 Registered: Jul-05
Friday, November 25, 2005 - 15:01 GMT the advantage the PG has over the others is that flexible ohm load feature , but the others are no slackers though.....
Username: Aznegg Post Number: 24 Registered: Oct-05
Friday, November 25, 2005 - 17:08 GMT does the pg xenon have a damping factor ive looked for the specs but the ones on the official website suck lol..... and i cant find out whether it does or does not. any help would be appreciated.
