Bronze Member Username: Big_edPost Number: 95 Registered: Jun-05 | 2 12 inch alpine type Rs with diamond D61000.1 or 2 RE SEs with orion 1200 D???? also 1 12 SX with diamond D61000.1?? Which will have the best SQ? |
Gold Member Username: RovinTrinidad & T... Post Number: 2236 Registered: Jul-05 | i would pick 2 RE SEs or 2 12s D6 Diamond subs with orion 1200 D for a mixture of SQL ...... |
Bronze Member Username: Big_edPost Number: 96 Registered: Jun-05 | thanks rovin |
Bronze Member Username: Big_edPost Number: 97 Registered: Jun-05 | or what about a single 12 or 15 SE with a jl 500/1 or kicker 600.1 ... which would be the better amp |
Gold Member Username: RovinTrinidad & T... Post Number: 2246 Registered: Jul-05 | Kicker - been posted that those RE subs can handle more than rec & those Kicker amps are actually underrated ........ |
Bronze Member Username: Big_edPost Number: 98 Registered: Jun-05 | the orion 1200D puts out 725 watts rms @ 2 ohms.. would that be too much for one |
Gold Member Username: RovinTrinidad & T... Post Number: 2302 Registered: Jul-05 | Can work - if u want to be cautious check the Kicker instead . Kicker is also underrated but i don't know by how much ..... |
Bronze Member Username: Big_edPost Number: 99 Registered: Jun-05 | do kicker amps put out clean SQ?? |
Gold Member Username: RovinTrinidad & T... Post Number: 2305 Registered: Jul-05 | Kicker is an amp heavyweight that performs well . If u want total SQ then look @ amps like Zapco , Xtant , ARC & others - but it's like 2/3/4 times in $ ......... |
Bronze Member Username: Bga44Post Number: 14 Registered: Nov-05 | hifonics and kicker are very good amps. kicker subs are good for SQ, but i dont know SQ for the amps. |
Silver Member Username: Big_edPost Number: 101 Registered: Jun-05 | what about.. Alpine MRD-M605 600 watt mono amplifer Eclipse 33230 600.2 JBL GTO601.1II - JBL 600 Watt Mono Amplifier JL 500/1 Kicker 04KX600.1 which out of those amps will put out 600 watts rms with the best SQ for one RE SE 12 |
Silver Member Username: LanzarchampBakersfield, California United States Post Number: 227 Registered: Sep-05 | id go either with the kicker or jl |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1225 Registered: Jul-05 | Hifonic makes ok amps for the price, there is no reason for u to buy one just save ur money and get what u want |
Silver Member Username: Big_edPost Number: 102 Registered: Jun-05 | il go with the kicker then cuz it meets the SEs rms and is a bit cheaper |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1239 Registered: Jul-05 | Get the RE SE's and a Kicker KX1200.1 |
Silver Member Username: Big_edPost Number: 103 Registered: Jun-05 | if i get 2 im probially going to get the orion 1200D.. im still decideing if im gettin 1 or 2. if i get the 1200D will i have to upgrade my alt on my 2002 monte carlo ss and how how much would a HO alt cost? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1242 Registered: Jul-05 | u would, try these guys, just call http://www.excessiveamperage.com/ btw: the kicker is better |
