Whats the difference between slot ports and round ports
Post Number: 59
if i tune a box to 26 with a slot or round port, wouldn't it sound the same? why do some boxes have slot ports and some have round ports? is it just for looks or what.
great question !
I'll bump it up 4 him
& i used to think that we on this forum thrash talk & talk crap
http://forum.sounddomain.com/ubb/ultimatebb.php?ubb=get_topic;f=55;t=036507
Username: Bumpnthump05
US
Post Number: 7
Slot ports tend to have no whistling or howling in terms of how the air comes out of the box but with a round port u can usually hear the air coming out
Username: Thumper
Richmond, VA U.S.A
Post Number: 150
Port noise..... you can hear it on any type of port. Usually when the edges of a port are sharp, or have well defined edges, it makes a whistle kind of noise, but if you sand down the edges to where the are smooth and well-rounded, then ye should not have any port noise
Username: Redskin
LondonEngland
Post Number: 187
If you haven't enough port area you will get port noise. It doesn't matter if your port is square, round, triangular, pentanganal, octaganal or even a rectangular slot if it's to small it will make a noise.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 731
pentagonal port .. now that would be cool
