I could use some advice
Username: Thejackal
Kansas
I'm looking to get a sub for my first system, and while I've looked around some, I'm wondering what people would recommend for me. I have a very limited budget which is around $400 for everything. A few subs which I'm looking at are Alpine Type-Rs, Cerwin-Vega V-MAX, And Kicker Comp VRs.
Hopefully, I can find somthing that gets loud but doesn't sound like garbage, and maybe some suggestions on amps. Since I listen to lots of rap and rock, It looks like a ported box is the way to go.
Username: Rovin
Trinidad & T...
Post Number: 1732
"around $400 for everything" - u mean 2 12s & an amp for it ???
Username: Thejackal
Kansas
That would be nice, but I can settle for one 12" at that price.
Username: Rovin
Trinidad & T...
Post Number: 1734
ok ,if its $400 for 1 12 & an amp
then 1 12' type R 4ohms DVC = $136 online shipped http://www.carstereoland.com/shop/shop_goodsview.asp?Top=1&g_code=20057117255390 57298
& http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14927
= $258 shipped .......$6 change to buy drinks.
Username: Thejackal
Kansas
Thanks, and this wont kill my stock alternator will it?
Username: Rovin
Trinidad & T...
Post Number: 1735
Not really - anything over 1000wrms might call for a upgraded alt .
what else is going with this set-up ?????
Username: Thejackal
Kansas
I already have an alpine deck and some kenwood speakers.
If I'm going with a ported box, are there any decent premade ones that will go nicely with the Type-R, or will I have to build one?
Username: Rovin
Trinidad & T...
Post Number: 1736
Easiest way to tell if your system needs more juice is if headlights start blinking ....
Go slot ported - U will have to go on Alpine's website tech pages & check the rec box volume & tuning freq .
A box for it online is about $50 so look for 1 made of 3/4 mdf ,with the rec vol & tuning freq .....
Username: Thejackal
Kansas
Alright, thanks again.
Username: Thejackal
Kansas
http://www.circuitcity.com/ssm/Bass-Slammer-Single-Vented-Subwoofer-Enclosure-BS 112V-/sem/rpsm/oid/119723/catOid/-13094/rpem/ccd/productDetail.do
This looks like it will work, but I can't seem to find anything that is under the $100 range for boxes. Does anyone know where I might be able to get one for cheaper?
Username: Rovin
Trinidad & T...
Post Number: 1744
http://sonicelectronix.com/cat_215.html
sub/box combos
http://www.woofersetc.com/index.cfm?fuseaction=category.display&category_ID=14&m fg_account_ID=48&sort=account_name&=Update+Selection
u need to google & not look @ those big name stores
Username: Solacedagony
New Jersey US
Post Number: 550
It might benefit you to learn how to build a box yourself because of how much it costs to buy and ship a box. Just a thought on my part.
Username: Thejackal
Kansas
Post Number: 7
The problem with the ones at sonicelectronix is that they don't say what the volume is them.
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 103
try klausaudio.com they'll build you a custom box for a pretty good price
