Bronze Member Username: XdreamSherman oaks, Ca Post Number: 14 Registered: Oct-05 | whats a good amp that will make this 1 sub bump hard. i think the results can be acheieved with a 200-300 amp? could be a discontinued amp am i wrong? please name some good amps that will make this bump. |
Bronze Member Username: Eprussian07Post Number: 48 Registered: Oct-05 | Isn't the 12 SX rated at like 1000W RMS? If so, and if you have the money I think the jl 1000/1 amp should be pretty good... Just look for a good-bran name company;s amp that puts out 1000W RMS. |
Bronze Member Username: XdreamSherman oaks, Ca Post Number: 16 Registered: Oct-05 | ok i dont really know whats good but out of the ones i saw i liked these the best cause they are not that expensive. which out of these 2 is better. and are any of them capable to making 1 12" re sx bump really really hard? 1. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14799 2. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14926 |
Silver Member Username: Comp98Philadelphia, PA USA Post Number: 114 Registered: Sep-05 | mike, the alpine isn't 1 ohm stable, in fact I haven't seen a 1ohm stable Alpine amp. (i could be wrong) I'm also getting a SX12 and bought a MB Quart Reference RAA1000. You should try to find one of them. (make sure it's the ones made in the USA, Mb Quart was recently purchased but thier old stock is still top of the line.) |
Gold Member Username: RovinTrinidad & T... Post Number: 1415 Registered: Jul-05 | I would buy the RE 1200wrms amp - its around $380/400 or brands like Orion 1200 ,Phoenix Gold 1200 xenon, Kicker KX1200.1 ,MTX TA7801 ,ED 9 |
Bronze Member Username: SixFlint, MI U.S.A. Post Number: 30 Registered: Oct-05 | ///ALPINE. |
Gold Member Username: RovinTrinidad & T... Post Number: 1419 Registered: Jul-05 | A single SX is a dual 2ohms sub which can only be wired @ 1ohm or 4ohms . None of Alpine's curent lie of mono amps can go down to 1ohm & is not powerful to power 1000wrms @ 4ohms so thats out . http://www.the12volt.com/caraudio/woofer_configurations.asp |
Bronze Member Username: XdreamSherman oaks, Ca Post Number: 18 Registered: Oct-05 | thx for the help. so far i like the re amp and the kicker kx1200. ok i have a few questions? are there any cheaper amps that can do the same thing? or should i just get one of these or better because they quality will be worst if i go cheaper? and also if i have 1 12" re sx and either one of these amps inside a car trunk, will it bump really hard inside and outside? and also is it a bad idea to get a refurbished kx1200? what could possible be wrong with them? like would it bump like a w7? |
Bronze Member Username: BestmankindPost Number: 24 Registered: Oct-05 | if your thinking about kicker kx1200 then why not just get the jl audio 1000/1? i have kx1200 and i like it alot but if i think jl audio is better. i think they are about same price if i am not mistaken. |
Bronze Member Username: XdreamSherman oaks, Ca Post Number: 19 Registered: Oct-05 | na the jl is much much more |
Gold Member Username: RovinTrinidad & T... Post Number: 1423 Registered: Jul-05 | Its like an investment in something good - so buy a good product & u will not be thinking "wonder how better it might have been only if i done that" Depends on box, car int shape , install ,settings etc - but u will be getting some powerful equip so thats a nice start . IMO - i like new stuff so there's peace of mind ! |
Bronze Member Username: XdreamSherman oaks, Ca Post Number: 21 Registered: Oct-05 | rovin would this box be good? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5817793178%26&sspagename= STRK%3AMEWA%3AIT%26 |
Gold Member Username: RovinTrinidad & T... Post Number: 1426 Registered: Jul-05 | Check the tech section of www.reaudio.com according to them for SQL - volume should be 2.5 cu. ft. & tuned to 35hz so that should be your guide. I'm not seeing the freq on your link |
Bronze Member Username: BestmankindPost Number: 26 Registered: Oct-05 | check out amazon.com they are similiar in price |
Bronze Member Username: XdreamSherman oaks, Ca Post Number: 22 Registered: Oct-05 | on ebay the kx1200 is like $350 |
Silver Member Username: Comp98Philadelphia, PA USA Post Number: 118 Registered: Sep-05 | lol why do I even post. The kicker is a great choice. Make sure it's not 'B' stock or refurbed and ask for a warranty before you even purchase. Like I said before, Alpines aren't 1 ohm stable and IMO get the MB Quart's while thier still have products made in the USA. |
Bronze Member Username: XdreamSherman oaks, Ca Post Number: 23 Registered: Oct-05 | mb quart one u should me is kinda underpowered and expensive! i think the kicker i want is b stock what could possibly go wrong? ok i found a jbl bp1200 and should i get that instead of the kicker kx1200? what do u guys think? |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2415 Registered: Aug-05 | b stock? |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2416 Registered: Aug-05 | is that returned items.... |
Bronze Member Username: XdreamSherman oaks, Ca Post Number: 24 Registered: Oct-05 | yea thats like refurbished |
Silver Member Username: Comp98Philadelphia, PA USA Post Number: 119 Registered: Sep-05 | no, b stock is not refurbished. B stock is the stuff that doesn't meet the requirements of a company. It produces lower wattage. Kicker kx1200.1 retail is A stock, does what it's supposed to do plus more. Kicker kx1200.1 B stock, may do what its rated at but its probably lower rms wattage. DON"T BUY B STOCK !! p.s. The MB Quart RAA1000 is rated at 1,000 watt RMS at 1 ohm (in fact it does more than that). A single RE SX12 needs 1000 watts RMS @ 1 ohm. I don't see how it 'kinda' underpowers the SX12. |
Bronze Member Username: BestmankindPost Number: 28 Registered: Oct-05 | so Comp98 do you know the price range for the A stock kicker kx1200 and the A stock JL audio? |
Silver Member Username: Comp98Philadelphia, PA USA Post Number: 123 Registered: Sep-05 | A stock is just retail.... just go to any online retailer except Ebay. They all sell A stock aka regular stock. The only place I've heard of selling 'B' stock is Ebay. |
Silver Member Username: Comp98Philadelphia, PA USA Post Number: 124 Registered: Sep-05 | If your gonna do Ebay the Kicker kx1200 should go about $360-$400 shipping included, but read the entire auction a few times over and ask seller questions before you place a bid/buy it now. You want to stay away from refurbs, remanufactored, and B stock. If you look at the lower priced kickers the auctions say B stock or remanufactored. Thats why they are cheaper!! |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 527 Registered: Aug-04 | orion XTR 1000 they have them on ebay for like $249 my buddy bought one for a SX 15 i personally have a SX 12 with an orion 1200D the new one. it makes my sub slam hard |
