Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 323 Registered: Apr-05 | what 1 is better iam hearin the type r will take the re sx |
Silver Member Username: Comp98Philadelphia, PA USA Post Number: 111 Registered: Sep-05 | IMO, take the SX. Think about it this way: You meet some friends and they all have car subs. How many do you think will have the SX? How many would have the R's that BestBuy recommends to eveyone? More than likely none of your friends will have even heard of RE. I consider that a 'good' thing. ohh and the Sx can handle more power : ) |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 324 Registered: Apr-05 | ya dats true about no1 nos about re but the guy from tcab said the type r will take the re sx an i dunno wat 2 get iam orderin them in feb so any1 got nething 2 say thankx gonin wit 1 15 in a 3.8cuft box tuned 2 30hz wit a 4inch wide port |
Silver Member Username: Iufan4lifeulPost Number: 552 Registered: May-05 | If you can get adequate power to the SX it will blow the Type R OUT OF THE WATER in SPL... In SQ though, the R might have the upper hand even though the SX doesn't have horrible SQ. |
Gold Member Username: RovinTrinidad & T... Post Number: 1349 Registered: Jul-05 | Guy who said the R will take the Sx must be high ! A 12" R = 500wrms while a 12" SX = 1000wrms so thats an unfair fight . Even a 15" R which is = 750wrms could not step up ..... |
Gold Member Username: RovinTrinidad & T... Post Number: 1350 Registered: Jul-05 | Just some useful info , btw ....... RE - 175wRMS -- DVC 4 ohm SE - 600wRMS -- DVC 4 ohm SX - 1000wRMS -- DVC 2 ohm XXX - 1600wRMS -- DVC 2 ohm, QVC 2 & 1 available MT - 2500wRMS to 5000wRMS -- DVC .7 & 1.4 ohm, QVC .7 & 1.4 ohm |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 326 Registered: Apr-05 | it will b powered wit 1 ed nine 1 with 1,200w @1ohm an the guy who said it was mark from tcab |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 327 Registered: Apr-05 | whats my best bet 2 12 re sx in a 1.9cuft box tuned 2 32hz wit a 3inwide port or 1 15 re sx in a 3.8cuft box tuned 2 30hz wit a 3 or 4inch wide port an they will b powered wit 1 ed nine 1 amp what 1 will b louder the 1 15 set up will b cheaper in the long run any thoughts |
Silver Member Username: Audiobass10Cape Coral, FL United States Post Number: 287 Registered: Jul-05 | "ohh and the Sx can handle more power : )" Actually, I think you'd be suprised. "If you can get adequate power to the SX it will blow the Type R OUT OF THE WATER in SPL... In SQ though, the R might have the upper hand even though the SX doesn't have horrible SQ." Again, suprise suprise... Check this out. http://forum.soundillusions.net/showthread.php?t=53780 |
Silver Member Username: Riebread77Post Number: 678 Registered: Jun-05 | he did burps...not continuous...he also didn't try to strap the amps to the SX so he has some inconsistencies in his test. |
Silver Member Username: MixmastaspigOkanagan, B.C Canada Post Number: 171 Registered: Sep-05 | So are you saying I should stick with my Type R subs then? |
Silver Member Username: Riebread77Post Number: 679 Registered: Jun-05 | i've also heard 2 12" type R's...they weren't coming close to 148 db...lucky if they hit 130 db |
Silver Member Username: MixmastaspigOkanagan, B.C Canada Post Number: 177 Registered: Sep-05 | I hit 139.6 db with 2 12" Type r's running off an XPLOD amp, 5th place in DB drag |
Gold Member Username: James1115Wilton, Ct Post Number: 4084 Registered: Dec-04 | port wars? I know that wasnt legal! if you claim it was I want a description of your system, in what vehicle, what box, what amp everything because I don't buy it at all! |
Josh CCS Unregistered guest | There was a guy at a local show I went to running 2 10" type r's, ported box I think just under 2 cubes in the back of some small hatch back (foreign somethin or other, about the size of a daytona). He had 2 boss rt2500ds and was hitting 142.something. There was another guy there with 2 of the newer type rs (10s still) in a grand am who folded the seats down, sealed off the trunk, used something like 4 aeroports and hit 144.something. Impressive for a cheap sub. And both of these cars were in street a in db drag, mic on the dash (well, mid windsheild, passenger side). |
Silver Member Username: Audiobass10Cape Coral, FL United States Post Number: 288 Registered: Jul-05 | "he did burps...not continuous...he also didn't try to strap the amps to the SX so he has some inconsistencies in his test." What isn't consistent about burps? Yes he did try strapping the amps for the SeXXX and SX..they simply couldn't handle the power. "port wars? I know that wasnt legal! if you claim it was I want a description of your system, in what vehicle, what box, what amp everything because I don't buy it at all!" What score don't you believe? |
Silver Member Username: MixmastaspigOkanagan, B.C Canada Post Number: 191 Registered: Sep-05 | He Didnt beleive mine 139.6db Nope Western finals for USACI in Kelowna Andreas held it,DB Drag NOT port wars LEGAL on the front windshield, I can even scan my certificate saying I hit it. Check out the link im in 5th place STREET B, I hit 139.6 in the finals and got beaten thats why only 139.2db showed up.. Mike Bellamy is me http://www.termpro.com/asp/eventresults3.asp?Event_ID=7980 I have an 89 ford escort, 2 12" type R's in a ported bass worx sub box running of the NEW line of SONY XPLOD amp the 1400 class D mono AMP http://www.procarsound.com/catalog/product_info.php?manufacturers_id=10&products _id=476&osCsid=c5ea4cb29a60f91d946878156c596276 |
Bronze Member Username: Sinx85Post Number: 77 Registered: Sep-05 | damn man , it took me awhile to make my mind for re sx 10" and now type Rs are beating it ![]() any one plz give me an honest openion and tell me if i am better of with 2 type Rs or re sx. your reply is very much apprecaited thankyou |
Silver Member Username: Camaro155mphPost Number: 258 Registered: Aug-05 | Scott, in about 10 days i can give u the results of a first hand test between the 2 subs you mentioned. My friend has Type R's, and I just purchased a SX15. I will put money down that my SX15 will have the same if not more SPL than his 2 12" type R's. Once I get my sh!t hooked up we are both going to meter our systems, on the dash, windows down..... |
