Silver Member Username: MixmastaspigOkanagan, B.C Canada Post Number: 190 Registered: Sep-05 | What size of wire is optimal to run from the amp to the subs? Does the amp's rms matter at all? thanks! |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1262 Registered: May-05 | 12 aug is fine. i run 8 aug but there really isn't any difference. some say 14 aug is fine for subs, but i personally notice a difference in my amps' efficiency between 14 and 12. |
Gold Member Username: CarguyPost Number: 4787 Registered: Nov-04 | It'll depend on your amp's power. For under 1000w, 18gauge - 14 gauge works fine. Above 1000w, 12gauge - 10gauge works. Close to 2000w, 8 gauge will do nicely. Don't go any lower than that. Just a waste of money. Remember, with output power, there is no high current, just voltage. |
Bronze Member Username: Eprussian07Post Number: 29 Registered: Oct-05 | I think www.the12volt.com has all the gauges and stuff wires and stuff... check it out, good site. |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1271 Registered: May-05 | aug..? AWG. working too hard ![]() |
