Kicker Solabaric L7
Username: Cplaya280
Quakertown, PA USA
Post Number: 57
how is this sub compared to any other, is this a good sub.
Username: Eprussian07
Post Number: 41
It doesnt compare in SQ, but it will outbass a LOT of things :-)
I personally hate those subs, it does muddy-poo retarded SPL for the 3 months that you will own it before it breaks. Just MO.
Username: Cplaya280
Quakertown, PA USA
Post Number: 59
well thats what i really want is really loud thumping bass, i hear alot about alpine type-r's. Type-R's prob have better sound quality but the kicker has more bass? is that right
Post Number: 45
Absolutely, and the price is a little different ;)
The thing I dont like about kicker:
The square sub design creates pressure points, which cause distortion, uneven pressure and will eventually tear down the sub.
the only thing the l7 does is create crazy amound of dirty base, thats it. I would honestly choose the type R's over the l7, wont give you nearly as much SPL but will sound a lot better and cleaner.
At the same time, I would also choose different subs over the type-r.
If you want crazy SPL check out the .MT line from RE.
www.reaudio.com
Thats a crazy SPL sub that is crazy-loud and dont distort and is a well-build amazing subs. Just my 0.02.
