Quick question
terry6405
when an amp says 500rms x 2 at 2ohms does that mean is will push 500 watts rms to each channel and each channel has a 2 ohm load or 500 watts at 1 ohm per channel?
Username: Carguy
Post Number: 4476
It means you'll get 500w rms per channel as long as you give 2ohm load each.
