Advice on what amplifier to buy all help really appreciated
Username: Yuro25
Post Number: 10
hey just bought 2 ALPINE SWX-1242D 12" 6000 WATT SUBWOOFERS PAIR TYPE X subwoofers and i was wondering what amplifier i should buy for them that is around 400 dollars. Thanks alot here are the subwoofers specs
carbon fiber/aluminum honeycomb cone
high-roll Santoprene rubber surround
cast aluminum frame
dual 4-ohm voice coils
frequency response 23-200 Hz
power range 500-1,000 watts RMS (500 watts per coil)
peak power handling 3,000 watts
sensitivity 83 dB
top-mount depth 8-11/16"
sealed box volume: 0.65-1.25 cubic feet
ported box volume: 1.0-2.0 cubic feet
Username: Rovin
Trinidad & T...
Post Number: 860
@ that price u will not find anything .
another option is 2 amps - 1/sub .....
Username: Carguy
Post Number: 4436
That Alpine sub will not handle 6000w. If you're lucky, it'll handle 1000w without distorting much. Lot of the so called 1000w will peak around 800w rms, then start bottoming out.
