Does it matter....
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 419
What company you get a wiring kit from off ebay? Like i know power acoustik makes crappy subs and amps but it would be pretty hard to screw up a wire. Would I be safe going with them?
Username: Invain
Michigan United States
Post Number: 3591
Sure. You or you could buy a kit from www.knukonceptz.com - The problem with most crappy companies is that they falsly advertise the size of the wires in the kit. You buy a 4 gauge kit and it's closer to 6. I think Knukonceptz kollosis 4 gauge is actually 3 gauge...
Post Number: 420
how would this do for me? http://www.knukonceptz.com/productDetail.cfm?prodID=eKo-K4
Username: Jmloughrey
Farmington, CT
Post Number: 1370
Knukonceptz is great wiring.
Username: Xkawn
Post Number: 104
how would one know if that would be good for you when we don't know exactly what your installing???
Username: Invain
Post Number: 3600
Wire is wire? Just make sure your using the right gauges for your amps. Speaker wire size doesn't really matter. Anything between 12 - 20 gauge is fine.
Username: Matt12490
Benicia, California
Post Number: 185
How do we know what size gauge to use for our amps?
