Dual amp installation question....
Username: Xkawn
Post Number: 39
ok, i'm looking at my amps and it looks pretty straight forward, but one question i have is. if your hooking up two amps the remote turn on wire needs to get to both of them, but the first amp has remote input, but no remote output to send wire to the next amp. due you split the wire or something???
thanks.........
Username: Xdrummer03
Tenessee
Post Number: 119
Yeh you can split the wire.I would just run it to one amp.Then run another wire from that terminal to the other amp.
Username: Carguy
Post Number: 3889
Get power distribution block for pos and ground. It'll make it much easier for the install and is the proper way.
