I'm wondering what everyone has used to power their 12WO? Which ohm did you have also? What are your thoughts on how it sounded, and what type of enclosure you had. I know this is the lowest end model, but It's still a JL.
Someones HAD to of owned this Sub, or hear it before?
my uncle has one he's running it off a PG amp not sure of the watts but its in a sealed enclosure, it sounds real nice! but JL is way over priced, and there are better choices out there.. but JL is a great company
I had a couple 10w0's once... You really don't need much to power them sufficiently, and still sound good. I'd say 200W per sub sounds pretty good... might be a little much, but i say a little much is better than not enough. Give yourself some head room, have everything set properly. It'll sound great.
