How do i noe a good sub wen i see wun
Username: Pootie69
Post Number: 8
what do i look for wen i want a sub that kicks a*s and how do i no a good sub from a weak sub
Username: Big_oso
Post Number: 377
Use the search button easiest way to find out which sub is good and which ones are bad.
Username: Taylor17
Kopperl, Texas
Post Number: 2751
Anything that sounds too good to be true.
If it says 1000 watts rms, and is only $75... it isn't a good sub.
Just look at the price, and rms.
Username: Big_oso
Post Number: 381
Well Taylor, as we all know RMS does not mean anything when it comes to the lower end of the car audio chain. But as Taylor stated Good equipment is not cheap. Cheap equipment is not good. You get what you pay for.
Username: Jonathan_f
GA USA
Post Number: 4412
"How do i noe a good sub wen i see wun"
If the words written upon it are spelled correctly :P
Other than that, it depends on the application. You can't really generalize because there are so many ways to design a good sub, and there are so many cheapo companies that try to woo you with peak power ratings, magnet weights, and huge surrounds.
Username: Carguy
Post Number: 3875
A good sub will wink back at you when you whistle!
You really can't judge a sub by it's appearance.
Username: Basshead86
Ocala, FL USA
Post Number: 338
it's all about the materials used, and all of the specs of the sub, not just how much power you can throw at it*cough* solo-x *cough*:-)
Username: John8x12
Post Number: 58
The good sub's are the one's that don't give you detention for talking in class.
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 109
a good sub looks at you and says "hey sexy want me to suck your amps d**k"
Username: Cnafets
Post Number: 93
A good sub is one that uses fresh ingredients.
Username: Chrisklein
Post Number: 108
You guys are freaking getting be hungry.
Username: Phuktupbasshead
Scottsdale, Arizona United State...
Post Number: 191
A good sub can go totally undetected directly below any enemy ship - no matter what technology they are equipped with.
