HIFONICS Brutus BX1000D
Username: Thelonewolf
Post Number: 71
Is the HIFONICS Brutus BX1000D a good(doesnt need to be awesome, will it power them and be alright) amp to power 2 10" MTX Thunder subs? RMS between 250-500 each sub 4ohms each?
Username: Carguy
Post Number: 3815
I wouldn't recommend it, but if you're on a tight budget and want lot of noise, then it'll do.
Post Number: 72
i am just looking for something to power my subs hit a bit and sound pretty good, nothing awesome just good, for cheap about 200$ shipped
Username: Iowahawks19
Post Number: 392
yea it'll do, the only way to get better for the price would be go used amps or maybe an audiobahn
Post Number: 73
im staying away from audiobahn, so this will sound ok powering 2 mtx 10" thunder 6000 subs?
