Jl help
Username: Igotpenguinz
Mi
Post Number: 36
ok, I've always wanted jl and i finally got it (1jl 1000/1 and 12w7) But, they're not hitting hard. I think it's my wiring. How should i wire it?
- any other tips appreciated
BabyBrock
could be the enclosure
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 731
How do you have it wired now, and is the enclosure to JL specs??
Username: Spyder
Eglin AFB, Florida USA
Post Number: 39
Did you voltage set that amp? and what is the size for that box?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 551
shouldnt matter how you wire it so long as its within the stable omh ratings.. 1.5 - 4 it gives the same amount of power regardless of load or voltage.. list your box specs
Username: Hurleyblink
Post Number: 82
uhmm u still got the ol stock alternator??
