Amp power holes to small
I got some 2 gauge wire and the amp power holes are way smaller then the wire i cant find no pieces to put on the end on the wire to fit the holes any suggestions
Username: Araknid
BOCA , FL U.S.
Post Number: 915
Trim the wire end till its small enough to fit.
Username: Josh2289
Post Number: 8
wont that take away power?
Username: Araknid
BOCA , FL U.S.
Post Number: 920
um no, inside the amp, the power branches off into smaller wires anyway.
