Question about a box on ebay...
Username: Tips
Post Number: 126
ok, im gonna buy one alpine type r and put it in a ported box. the thing is i dont kno what type of box to put it in. i found two on ebay...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5788784552&category=50568 %26
and...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5789587787&category=32823 %26
i don't know why the second one is so cheap and if it'll be able to hand the 500w rms of the sub. the first one is 1.8 cubic feet, but the type r is supposed to be 1.0-1.75 in a ported. do i have to account for the actual room the sub will take up? Should i just drop these boxes and try to find something better?
Username: Addicted2bass
Miami, Florida USA
Post Number: 909
yes you have to account for the space that the sub takes up.i say you should drop the boxes and find something better suited to your subs specs because those sub enclsuore dontl ist the tuning of the port. the 1st one could work if it listed the port tuning..But i still say build yor own enlsoure..you'll have better results if you build it yourself to the manufactuars specs.
BTW..totally drop the second box from your choice..it'll make the sub sound horrible
Username: Tips
Post Number: 127
how do i build my own box? my cousin built his box for his and it compleylet fell apart... of course he just used random wood from his garage and nailed it together and cut a hole... lol. but what type of wood would i use? and how would i put the pieces together? just use a lot of nails? do i seal it?
Username: Jaackdeth
United States
Post Number: 227
http://www.bcae1.com/
Username: Jmloughrey
Farmington, CT
Post Number: 1311
use MDF for the wood, most people use wood glue and a drywall screws to hold it togehter then go back and seal everything up inside with silicone caulk.
www.bcae1.com would be a good place for you to read...
Username: Tips
Post Number: 128
thanks
