Need Help from the experts!!
Username: Jaackdeth
United States
Post Number: 172
Ok, first off I'm not BIG time with car radio so cut me a break ok!
90 Caddy Deville
HU is an ALPINE CDA-9835
Front speakers are Rockford 4x6's
Read deck speakers are Rockford 6x9's
Amp for in car speakers is a Phoenix Gold OCTANE R5.0:4 4-Channel Amplifier
Subs in trunk are 2 12" Precision Power DCX 12 Subs
Running them is a HIFONICS BX1500D MONO AMP!
Running a stock 120 amp alternator, and 4 gauge wiring for the amps!
My question is that I need to turn the gains way up on the amps to get anything out of them. I have good grounds.
This HU puts out 4 volts for the sub, and the amp for the subs is from 9 to .2, I have to run the gain on the amp to around 1 or so to make it sound half way decent.
Should I trash the whole idea here, or any suggestions would really be appreciated. Oh! I'm not looking for the biggest and badest system out there, just want the damn thing to work right.
Oh, the subs are in a prefab ported box,(i know, i know)
Username: Araknid
BOCA , FL U.S.
Post Number: 839
What is your bass boost set to on your amp? Is your sub level on your HU set to low?
Username: Jaackdeth
United States
Post Number: 175
Bass boost is set pretty high, now sure off hand, and the hu sub level is on 13 out of 15!!
Username: Araknid
BOCA , FL U.S.
Post Number: 841
And your bass is set high enough on the EQ?
Username: Jaackdeth
United States
Post Number: 176
Yes, where would be a good place to set it at?
Username: Araknid
BOCA , FL U.S.
Post Number: 842
What is yours set at right now? I know of poeple who just set theres to flat or even negative because when its to high it tends to clip or sound to punchy, but in your case you might need to crank it up. Also are you subs recieving enough power? What is there RMS and what are they recieving? Is your amp recieving enough amperage? what is the total fuse rating on the amp and do you have an inline fuse on your power cable, If you do what is the fuse rating?
Username: Araknid
BOCA , FL U.S.
Post Number: 843
And I know you have a prefab ported box is it at least the in the recommended size range for the subs?
Username: Jaackdeth
United States
Post Number: 177
Oh boy!! LOL the subs are suppose to be 1000 rms each, I don't think they are, and when I talked to GlassWolf about the PPI subs, he said Alpine R at 500 rms would be better. If I turn the gain up on the amp the subs come alive, and sound bumpy, as it only lasts for about 5 min at that level before cutting out.
The Hifonics amp is suppose to put out 1500 rms watts at 1 ohm, and that is how I have the subs wired. But again I know the Hifonics is over-rated. (How do I know if my amp is receiving enough amperage?) Man I sound dumb here. Here is the specs on that amp
1500 watts RMS @ 1 ohm
1000 watts RMS @ 2 ohms
500 watts RMS @ 4 ohms
1 Ohm stable design (perfect for dual 2 ohm subs)
0.08% THD
Class D mono amp
Ultra-Fi MOSFETS
Extreme powerful Power Supply
New ultra efficient design
Hot Illuminated Logo
Mounts comfortably
Fully Adjustable stable bass Crossover system
PWM power
MOSFET Power Supply
Free Remote Bass Boost with LED light on it.
Line Out
Variable Bass Boost @ 18db
Subsonic Filter
Simpatico Coil Design
Line Output for connecting multiple amps
Variable Bass Equalizer
Sub-Sonic Filter
Requires 4 Gauge Power Connectors
S/N ratio: 95 Db
Dual 60 Amp Fuses
If you are talking about the "rock", flat, pop I am on the rock for bass. And that box should be close. I know it's not to specs, but it should sound better then that, unless something is really wrong. Thanks
Username: Araknid
BOCA , FL U.S.
Post Number: 844
hmmm dual 60 amp fuses huh..... thats 120 amps the amp needs to operate to its full potential. you have a 120 amp stock alt. The car needs like 40 amps by itself and your also running another amp for your 4x6's and your 6x9's so it seems to me like you need a HO alternator then you can work from there. Also do you have AIM or somethin so we can talk faster and where do you live maybe someone on the board lives nearby and can check out whats goin on in person.
Username: Araknid
BOCA , FL U.S.
Post Number: 845
And also what is the voice coil config for the subs
SVC,DVC,2 ohm,4 ohm? don't remember if you mentioned or not but just to make sure and how are they wired.
Username: Jaackdeth
United States
Post Number: 178
I don't have AIM no, I have yahoo mess.
I live in Wi. I don't think to many on here!!
Do you think that amp is really using that much amps? Seems a bit much don't it?
Username: Jaackdeth
United States
Post Number: 180
bump
Username: Kd7nfr
Montpelier, ID United States
Post Number: 375
EXPERT IS ON THE SCENE! Wait... I'm not an expert... d@mnit!
Username: Illuminator
Post Number: 987
Do you have the subs wired in series or parallel?
Username: Jaackdeth
United States
Post Number: 181
Parallel, as they are dual 4 ohm subs, and I am running them at 1 ohm
Username: James1115
Wilton, Ct
Post Number: 3591
OK well if you are posative that it is wired correctly in parellel I would have to go against your amp. Those PPI subs are pretty good subs but like glass said I guess the type r's would better suit your needs. Those Hifonics amps are built like doggy doodoo with a awfull reliability issue and extremely high overratings on their power outputs. I bet you are lucky to get 500 watts out of that amp at 1ohm. A good way to get a good estimate of the amount of power your amp really puts out is to take the value in dollars and convert it to RMS power. So if the amp retails for $350 typically thats how many watts you can expect to get. Now of coarse theirare top of the line amps like sinfoni for example that will be a tad more expensive but its build quality that you pay for. If your looking for a good reliable amp to run that sub at 1 ohm look into the jl 1000/1,JBL bp 1200.1,kicker 600.1, kicker 1200.1(conservatively underrated), orion 1200d or 600d something like that but hifonics to me is JUNK!
Username: Jaackdeth
United States
Post Number: 183
Yeah that hifonics is leaving me with a pit in my gut, thinking that it's junk myself, guess the only way to know is to get a different one and see. Do JBL's go down to 1 ohm? I know kicker does!
Username: James1115
Wilton, Ct
Post Number: 3595
yup they are rated at 1200 at 1 and 2 ohms. Hey I was just reading this post a little more did you say you have dual 2ohm subs? if you have dual 2ohm subs and you are running them in parellel then you are getting 1/2 ohm which is way to low for that hifonics or most amps for that matter. I am not sure of many amps that can be run at 1/2 ohm mono. I know of a few that run at 1/2 ohm stereo. OK so your subs are dual 2ohm 1000 rms/piece?
Username: Jaackdeth
United States
Post Number: 185
No, they are dual 4 ohm
Username: James1115
Wilton, Ct
Post Number: 3600
0.08% THD "
ok because I saw this and figured they were dual 2ohm. If you got that off of hifonics web site it is wrong.
Username: Jaackdeth
United States
Post Number: 186
It was taken off ebay, I see that they have dual 2 ohm on there, but shouldn't matter I would think if I run dual 4's would it??? Confused now LOL
Username: James1115
Wilton, Ct
Post Number: 3604
if you are running dual 4 ohm subs in parellel then yes you have them going to a 1 ohm load mono to your amp. Those subs are 1000 watts peak so what you need to do is find out the RMS wattage and go from there. If you dont have the manual try to contact PPI directly www.precisionpower.com
Username: Jaackdeth
United States
Post Number: 188
They say that it's continuous power handling of 1000 watts, and a peak of 1000 watts... Now I know that continuous and rms are the same, but I never heard of the peak as the same??? What a set-up LOL, crap amp and speakers that don't make any sense. Not to get way off target here, but I wonder if 4 gauge wiring is big enough for the 2 amps!!
Username: James1115
Wilton, Ct
Post Number: 3606
yeah I only saw 1000 peak on the web site. under normal circumstance's 4 guage would not be enough for that kind of power you are running but like I said before that amp doesnt put out anywhere near its rating so you should be fine, remember the shorter the power wire and ground the more current the smaller wire can handle.
Username: Jaackdeth
United States
Post Number: 205
Ok, I'm thinking different Amp, and upgrade the wiring as well. Thanks for the help!!
