Advice
Username: Michaelp
Can someone out there give me some advice on what kind of sound system i should put into my 1975 Oldsmobile Cutlass?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8265
not until you give us a budget range, and what you expect from the system.. then we could start to work with ya
Username: Michaelp
i was thinking about $800 for starters, i was expecting something that the quality of the sound is good, and something to rumble my a s s
Username: Michaelp
and is there is any way that the interior wouldnt have to be damaged? Just incase I would like to sell the car with all the original interior.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8283
yes if you have it done by a professional at a higher end shop. they'd know enough to do an install without altering the interior.. but the labor is going to cost you at laest $800
Username: Michaelp
I know some friends that could install it for me, I was just wondering what I should buy.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8310
you can do a nice system without any vehicle modding, but you're going to need a lot of fiberglassing work.
glassed kick pods, glassed glove box or center console for the head unit, and MDF of glassed enclosure and amp rack for the trunk.
that'd be the way I'd do it anyway
Username: Michaelp
Thanks man, you really helped a lot, i was really lost before this.
