why doesn't anyone like pyle subwoofers. don't they hit hard. all i need is 2 dirt cheap 15" subwoofers that produce alot of ground shaking bass. i wanna be heard blocks away and i could care less about what brand the subs are as long as they are cheap, deep, and LOUD!!!!
cheap and good don't go together. nobody wants to hear you blocks away.. except hopefully the cops. pyle are cheap and don't perform that well. you get what ya pay for in this case.
if all you care about is cheap though, grab em and see what ya think.. at least you're not out much if ya do think they suck in the end
get 2 12 volfenhags 100+SHIPPIN an a dual ported box tuned 2 28hz an a amp at 10hm stable an u will b go0d it will sound go0od an alot of vibrations an it will sound go0od far away i have 1 right now an it travels pretty go0od i dk about 3 or 4 blocks may b 1 or myb 2
for $250 worth of subs...might as well go with 1-15" kicker L7 and port the crap out of it...i don't he's looking to spend 400-500 with sub and amp...
big john
well since cheap is obviously not da route to take what about 2 15" cvr kickers. i can get dem on ebay for bout $80 a sub. r those hard deep pounding subs cause i really didnt want volfenhag subs.
the CVR 15 is a fantastic sub. those will last you for years, and perform outstandingly. you'll want to power them with a decent amplifier, and put them in a good, ported box tuned to around 25Hz or so. you'll get good deep bass and tons of it.
when you do find a amp thats 1000 w rms tell us all the specs to make sure it will work with your configuration, i don't recommend any of the amps that i put maybe next to but they do treat you really well on a budget and are not horrible amps by any means just not that good of amps
The comp vr is like very awsome...heard em b4 and there awsome...get u either a couple 10's or 1 15 inch compvr and u will be heard...lol i love hifonics amps, not the most eficeint but cheap power
you could find a kicker kx1200.1 used on ebay pretty cheaply I'd bet. that'd give ya 600 watts per sub at 1 ohm. then ya just need two subs with dual 4 ohm coils each.
