Hook up multiple subs with one sub-out
OK i wanted to make sure i got this right before i actually tried it.. using a Y-cable
Headunit -> Y-cable1 -> amp1 - Sub1
-> Y-cable2 -> amp2 -> Sub2
Y-cable1 and Y-cable2 represent a different end of the y-cable.. i'm sure you get the rest, tell me if it would work please!
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 455
You can hook up multiple subs to one amp. Also, if you are using multiple amps with your setup does one of them have an output so you can daisy chain amps??
it's an ed NINe.1, i think it does..
Post Number: 457
How many subs you got and what are there specs?
(2) RE XXX12 1600RMS -> ported tuned to 35Hz
(2) ed NINe.1 1200RMS
Post Number: 458
Is your alternator even going to support that much wattage???
About hooking the amps together. If you go to ED's website it mentions that those amps are stackable and can then put out more power. If you allready have the amps and subs at your house, check out the manual it should give specs on it. You should not have to mess with using a Y cable at all.
