I NEED MIDBASS HELP
Username: Riebread77
Post Number: 102
Hey guys, I'm looking for a midbass speaker (8 inches) and they only requirements are that is has to have a mounting depth of 3" or less. No budget. Let me know of some of your ideas.
Username: Zero43
Kyle, TX USA
Post Number: 44
Ive been looking into cdt as a midbass myself
besidess them the only other manfacturer of 8 in midbass drivers that if now of is kicker which one you get depends on how high a freq. you want the kicker I believe go up to about 400 i think
But i know the cdts go up to 1khz so roll shouldnt be as bad at least thats what I would figure
Username: Carguy
Post Number: 3440
3" depth will give you almost no bass. What you need to do is get a 1" spacer for your speaker. That way it's like getting 4" depth.
Now you should have more choices/selections.
Username: Zero43
Kyle, TX USA
Post Number: 47
the depth of the cdt ef 8 which is what i was looking into is 3.5in and if needed you can mount it in an .3-.6 cuft box
Username: Jonathan_f
GA USA
Post Number: 4218
The Morel drivers are fairly shallow due to the hybrid magnets they use, check the depth on those. Morel makes awesome midbass drivers.
Post Number: 175
If I do get a spacer, what are my best options.
Username: Zero43
Kyle, TX USA
Post Number: 50
where exactlt are you planning on putting it
Post Number: 179
custom enclosure in the front doors.
