Amp trouble... needing help picking one out
donny aladam
i haven't got my subs yet but im going to buy 2 12" kicker cvr's (400wrms each) and wire them down to make a 2ohm load which will be 800w rms @2ohms.... well someone earlier told me to get the mtx801d and it'll run them perfect but i saw the specs and it's only 500wrms@2ohms and 800w DYNAMIC POWER @ 2ohms
will it still run them good or should i go with a different amp?
Username: James1115
Wilton, Ct
Post Number: 3412
kicker 600.1 will run them perfect.
donny aladam
also since i haven't got those subs yet what ones are better because they got both dual 4ohms n dual 2ohms i think imma go with the 4ohms n wire them in parralel to make a 2ohm load- sound good?
Username: James1115
Wilton, Ct
Post Number: 3415
yes thats perfect
donny aladam
how much is one of those gonna cost me because im on a pretty tight budget thats why im goin with the cvr's and those mtx's i can get for like 150$
and dosen't that amp only put out 600w rms?
Username: James1115
Wilton, Ct
Post Number: 3417
yes but it is underrated. it will put out close to 800.
