2 12" type R vs 1 12" type X ???
heeeelppp meeee
here it is, i have the alpine mrd-m1005 amp,
1000W rms and i want to get either one 12" type X sub 1000w with custom ported box or two 12" type R's 500w rms with ported box. what is better two type R's or one type X?? 2 R's vs one X.. what is gonna be the LOUDER!! system?? low bass and quality all that is fine.. but what is LOUDER??
pleaaase help. thanks.
Username: Subzer0
Richmond, KY USA
Post Number: 163
i like the r's .. they are more popular.
hellppp meeeeeee
but do u know what would be louder?
Username: Dpaw20
FL USA
Post Number: 252
ya, i got 2 12" type-r's and they sound great, especially for the money.
Also, they made a bad batch of type-x's so you might not even get ones that work.
I'd go with the 2 type-r's.
Also, dont go prefab ported. I made that mistake. Trust me, dont. If you get the r's, get a sealed box, or good custom ported.
