Alpine type r
Username: Shanmag
im thinking about gettin 2 alpine type r subs, would it be better to get 2 500W mono amps or 1 1000W amp for the subs?
Username: Darkseid
Post Number: 34
keep it simple, 1 1000 watt.
Username: Shanmag
would there be much difference in sound having 1 amp instead of 2?
Username: Thrushdtd
New York
what amps are you thinking about? keep in mind that two amps require more power i think
Username: Shanmag
Post Number: 7
i dont have any amps in mind actually, i was just wondering thats all
any recommendations tho?
Username: Kklagge
Post Number: 179
It also depends on whether you plan on putting both subs in the same box or if you're going to make separate chambers for each sub...it would be easier with either 2 amps or a 2 channel amp if you're going to go with separate chambers.
Username: Shanmag
Post Number: 8
how different would it sound between putting 2 in 1 box or having 2 seperate box/chambers for each sub?
Username: Shanmag
Post Number: 9
basically im looking to get that nice clear "hum" sound i guess u could call it, i duno i think it sounds good when ppl drive past and u can just hear from ages away the bass
Username: Shanmag
Post Number: 10
sorry, hear the bass from ages away
Username: Thrushdtd
New York
Post Number: 10
if you want that type of bass put the two subs in a huge ported box with 1.5 cu ft per sub with a 4" wide 14 in long port and always make two chambers. also get the 1000 rms watt amp and a good one beleave me it makes a difference. good luck
Username: Shanmag
Post Number: 11
thanx
any recommendations on a good quality amp?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 318
jl 1000/1 !
Username: Rzarector
Post Number: 319
make sure u buy a new alternator to :-)
