Silver Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 101 Registered: Apr-05
Posted on A speakers Q is a value of its electrical (Qes), mechanical (Qms), and total value (Qts) in relationshion to its character. A speaker with a high Qts (above 40) has been determined that it will be more effective in a sealed box compared than a ported enclosure. A speaker with a lower Qts (below 35) has been determined that it will be more effective in a ported box compared to a sealed box. You may use your drive any way you wish, but it will not perform at its optimum level if not used in the enclosure listed above. |
