In need of answers regarding building a wall in my explorer
knowledge seeker
I already have that brand so many hate supposedly Kicker l7 15s (if they do suck investment has already been made)but im wanting to build a wall for them and probably putting some 12s of some brand above them in the wall. 1st question Will this wall bump good if built correctly. 2nd Does somebody have in suggestions regarding 12s that will give me a wide band of tone frequencys to help bring in more tones
baser
Does anyone have any experience regarding subwalls
rule of thumb. dont mix different subs or different size of subs... its always better if you have multiple subs to have the exact same models. .... how many 15s do you have? if its only 2 you definetly dont need a wall... if you have atleast 4 then a wall may be a good idea even tho i dont particularly like walls. if you build the box good a sturdy and with the proper volume and give them 1000w rms from a good clean amp it should be very very loud. (note i said 1000w rms because i think thats what L7 15s require. if its more or less than do that)
