ward Unregistered guest | I am going to intall my system into my 1977 pontiac catalina and was wondering if one, anyone would reccomend putting sound dampeners in and two, what would be the best brand and wether it should be in sheet form or the spray. I have also heard foam insulating spray serves the same purpose is this true? |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 1627 Registered: Nov-04 | i would go with sheets, and try edead by elemental designs, od edead sv1. edead is 1 oer ft. and sv is 1.50 it will def. do the job. and i would def. put it in. it will eliminate most rattles in your vehicle |
Gold Member Username: Jonathan_fGA USA Post Number: 4032 Registered: May-04 | Foam sprays aren't as good, however, ceramic and polymer based sprays are excellent. Here are some examples: http://www.coollizard.com http://www.quietcoat.com/ |
ward Unregistered guest | Thanks alot |
