2 12's and amp combo??? help?
Greggs
right now i have sony amp 1200 watt (http://www.bestbuy.com/site/olspage.jsp?skuId=6254867&type=product&productCatego ryId=cat03085&id=1069302879573 ) and dual subs 12 inch 1100 watts ( http://www.bestbuy.com/site/olspage.jsp?skuId=7044085&type=product&productCatego ryId=pcmcat54900050004&id=1099396976115 )
i want to step up on my subs... they don't seem that loud any more... if i need to tune them a specific way, if u could tell me that'd be great.... i was then thinking to only use $200 to get some subs and amp possibly 3-4 hundred... but want to keep the price range down... here's one site i've been looking at.. good deals?? http://www.serious-sounds.com/Subwoofers/12%20Inch/
if you could help me thanks... much appreciated..
Username: Loc_out
Post Number: 205
fist off sell you Sony amp that a better on. Try ebay this sub are good for the money http://www.serious-sounds.com/Items/ALUM12N?
I had some 2 10's on a camaro they hit
Username: Loc_out
Post Number: 206
http://electronics.listings.ebay.com/_W0QQa10244ZQ2d24QQa14Z31314QQa31302ZQ2d24Q Qa31304ZQ2d24QQalistZa14Q2ca31302Q2ca31304Q2ca10244Q2ca3801QQcatrefZC3QQcatrefZC 6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQfromZR2QQfsooZ2QQfsopZ2QQf trtZ1QQftrvZ1QQgcsZ1549QQlopgZ3QQpfidZ1909QQpfmodeZ1QQreqtypeZ2QQsacatZQ2d100QQs ocmdZListingItemList
This is not a bad deal
Username: Tdbdrummer
Post Number: 283
GET THOSE VOLFENHAGS! I have two of them in a sealed box. Personally, they blow away any sub you can get at Circuit City or Best Buy or any of those retarded places. Can't comment on those Audiobahns. They may have a higher power rating, but the Volfenhags as well have Alum. cones. If you go with those they are pretty cheap on E-Bay and would prolly sound good ported. They sound really good sealed, but it sounds like you want all the bang for your buck, so go with something ported and tuned down to like 30Hz!
Greggs
are the legacy subs bad?? http://www.serious-sounds.com/Items/LWFX127?
Post Number: 285
Legacy sucks hardcore! If money is an issue get those Volfenhags. They are even cheaper on Ebay. You won't regret it. You won't be heard a mile away, but you'll get good bang and sound for your buck!
2001 blazer
Like i've said in the past i have 2- 12" cuspid subwoofers and a 1600w max amp... 2 x 80 rms... And they hit hard... i know what you're saying.... cuspid sucks... well thats what i thought until i bout the amp and subs for like $60 and put a 1 farad cap in . GREAT DEAL I THINK.... don't listen to people who diss cuspid... because i can tell you first hand that they are not as bad as people make them out to be and for $60 why not?
2001 blazer
kingdave7
dude go to www.shopzilla.com and type in 12in subs and they will find the best deals around for you, i used it and bought 2 kenwood 800watt subs for 48 bucks for one and they pound. bestbuy is trying to sell the same subs for 129$. shopzilla is amazing
Greggs
so i looked on ebay for audiobahn... this good deal?? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18803%26item%3D5775626945 %26
also what amp should i go with it if it is such a deal
Username: Mikechec9
Chicago/atlanta
Post Number: 88
no gripe against audiobahn amps, had one and loved it (peep the audiobahn threads on this forum). but i would greatly consider (again) the atlas's or avalanches. these are great subs and this deal is unprecedented. if i did not already have my brahmas i would nab these.
http://www.ascendantaudio.com/
just an opinion though.
