New member Username: VoodoochildeGreencastle, Indiana Post Number: 4 Registered: May-05 | Although I am still deciding on which sub to get I would like to know your opinions on which amp to get for each possible sub choice so I can compare prices and such. The subs I'm looking at are... 1) Avalanche 15 2) 2 Avalanche 12's 3) 2 RE XXX 12's 4) Re XXX 15 5) 2 ID IDMAX12 12's Thanks for your help because I'm new to Car audio and still learning. |
Silver Member Username: Sevin7Post Number: 150 Registered: Apr-05 | http://sonicelectronix.com/item_64.html |
New member Username: VoodoochildeGreencastle, Indiana Post Number: 8 Registered: May-05 | Thanks sevin...anybody else have any suggestions for reasonably priced but high powered amps. thanx |
New member Username: Andremac3000Post Number: 1 Registered: May-05 | what is the best kicker amp use to play S15L7 kicker sub. |
Gold Member Username: James1115Wilton, Ct Post Number: 3118 Registered: Dec-04 | well if you use ebay look out for a orion HCCA 250g4 to run one avalanche 15 thats what I run mine with and it rocks, if you run two look for an orion 2100, if you are running the REXXX then you are gonna need about 2500 watts so look into the kicker 2500.1 and if you go with the IDmax's go with something like a orion 275hcca. |
New member Username: Andremac3000Post Number: 2 Registered: May-05 | is there a website for kicker car electronics. i am seeking a kicker amp to play one S15L7 kicker sub. Thanks for your help |
Gold Member Username: James1115Wilton, Ct Post Number: 3124 Registered: Dec-04 | whats the power ratings in RMS not peak on that sub? |
New member Username: Andremac3000Post Number: 3 Registered: May-05 | the rms on the sub is 750 |
Gold Member Username: James1115Wilton, Ct Post Number: 3133 Registered: Dec-04 | so get the kicker 600.1 |
New member Username: Andremac3000Post Number: 4 Registered: May-05 | will this 600.1 amp play the S15L7 comfortably and which sub box is better a sealed or ported enclosure |
