New member Username: Mike13Post Number: 2 Registered: May-05 | i am getting a orion h2 15.4 and i have a 1600 watt sony mono amp i know not near the best but i have to work with what i have for now but how do i get a 2 ohm load out of this sub? thank you let me know. also what does everyone think of the orion h2 15.4 ive never messed with one thanks |
Bronze Member Username: CdjSouthern Ohio Post Number: 23 Registered: Apr-04 | This wiring wizard should help: http://www.rockfordfosgate.com/rftech/wiringwizard.asp |
New member Username: Mike13Post Number: 3 Registered: May-05 | thank you that helped alot what do you think about the orion h2 15.4? let me know |
Bronze Member Username: CdjSouthern Ohio Post Number: 25 Registered: Apr-04 | I've never heard an Orion sub, so can't really comment. Sorry! |
Silver Member Username: AraknidBOCA , FL U.S. Post Number: 567 Registered: Nov-04 | whats the model # of the sub? |
New member Username: TraymannsplTrenton, Mo USA Post Number: 8 Registered: May-05 | there you go man this way of wireing at 1 ohm should allow you to push more watts out of your amp if it is 1ohm stable if not the this should work if 2 ohm stablewire each seprate not together as in first pic but you know that wireing them each into 2 ohms you will suck more power from your amp and it want hit as hard.good luck. |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 1537 Registered: Nov-04 | i think that the h2 is a pretty good sub, there are people that will swear by them so they cant be that bad. h2 means hcca generation 2 |
Silver Member Username: Car_bangsPost Number: 118 Registered: May-05 | rockford wiring diagrams are worthless u couldn,t wire two kickers up like that they each have they're own chamber and wired from rhe amp ooooooaaaaa |
Silver Member Username: Car_bangsPost Number: 119 Registered: May-05 | and u can only have a 1 ohm load or a 4 ohm load with two dual 4 ohm subs |
