WC Unregistered guest | The power acoustik PC1.0 Blue, this is 1 farad right. |
Bronze Member Username: HurleyblinkPost Number: 16 Registered: Mar-05 | PC1.0 the 1.0 means one probably so i would say yes, and as for capacitors there all the same, there aint really much difference in them at all. |
WC Unregistered guest | What about the Stinger Pro Series SC201MSC, its 1 farad and has digital display. That is what I am looking for, a good under $100 1 farad digital capacitor. |
Bronze Member Username: HurleyblinkPost Number: 19 Registered: Mar-05 | dude go on ebay u can get them alot cheaper |
WC Unregistered guest | ebay, naw its cool (rather buy my sh!t on the street) yea I said under $100 I found one for alittle over that, but I want it NEW and from a place I can RELY on. So if something goes wrong, I can go off on the person. But I stopped buying stuff that is more than $100 off the sreets. |
duffdog Unregistered guest | then try parts express--thats a real store, they got good deals on caps. www.partsexpress.com |
Bronze Member Username: HurleyblinkPost Number: 23 Registered: Mar-05 | ebay is reliable as long as u get the product from a powerseller... |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 445 Registered: Oct-04 | There is a difference in cheap capacitors as opposed to quality ones. Build quality is a factor in just about any product you buy. |
WC Unregistered guest | I am either gettin the Stinger HPM Series SC201MNC or Stinger Pro Series SC201MSC from sounddomain. |
Bronze Member Username: Johnnyboy73Houston, Tx U.s. Post Number: 19 Registered: May-05 | caps are the same is you get them from a good manufacture. it doesnt matter if its digital or not though. the digital read out just tells you the voltage, which doesnt mean a damn thing, cause if you need to know, just hook up a voltage meter and it will tell you, you can get a good rockford fosgate 1 farad cap for right at $100 or so from best buy, not ebay or anytihng and its one of the best ive ever used |
Silver Member Username: Sevin7Post Number: 154 Registered: Apr-05 | http://sonicelectronix.com/item_3154.html $70 for 3 farads. |
Silver Member Username: Erik123456Post Number: 585 Registered: Aug-04 | power acoustik caps are terrible... i had a 2.4 farad one and it didnt do a thing besides light up blue lol....now i have a 15 farad alumapro and my lights dont dim with over 1400 watts (my alternator is a baby...70 amps) alumapro's "the cap" are really good and I would recommend them. The 5 farad can be had for 230ish if you look around I got a deal on the 15 and they let me trade in my other cap so thats why I went higher (also highout put alternators havent come out yet for my 05 car) Save up the extra 100 bucks and get something that will really help your system |
WC Unregistered guest | Yeah I think I will get the Stinger cap, so these caps really help out with lights dimming and bass? |
