Bet you can't Solve This Riddle
ImTheNewPope
NOw that youve been sucked in by my alluring title help me with my godamn amp. It was working fine powering my 2 subs until i played it too loud
and the sub cut off now i have the green power light on my amp on but it wont power my subs. My subs still work though because i tried hooking them up to my rear speakers and they werent blown at all
Username: Carguy
Post Number: 2989
Unhook all cables except power and subs. See if the amp has green light.
If it does, attach rca cable to amp's input connectors. With your thumb, touch the inside of the rca cable lightly. If the amp is okay, you should hear a hum. If not, then try the other rca channel.
If you hear nothing, then the amp is toast.
ImTheNewPope
I dont get the green light unless the amp is grounded, the rcas connected and the remote is hooked up.
ImTheNewPope
Scratch that even with all the wires connected the car has to be on and a cd has to be playing before the amps light turns on
ImTheNewPope
Anyone ?
Username: Zootreeves
York, Yorkshire UK
Post Number: 12
Check the the speaker wire/connectors are not shorted
Username: Noxxzious
Check the amp fuses, else its a Fried amp.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1441
you blew one of your channels its sounds like
York, Yorkshire UK
Post Number: 13
If you have one try a different amp with the same wiring, if that does not work then i'd say it was fried.
ImTheNewPope
took the amp in its blown had to get a new one thanks for the help
