Like
JL AUDIO??????
Username: Poof
Post Number: 25
Hey im getting a amp and i have 3 choices i need you opinions on teh best one either a JL audio e1800d 1000/1 or a hifonics BX2002
Username: Poof
Post Number: 26
i have 600$ also so nethign better than those i owudl need sugestions
Username: Alias747
Post Number: 41
If money isn't a problem, then there is no competition, the JL 1000/1 is one of the nicest out there, and definately the best one of those 3.
Username: Poof
Post Number: 27
This is for my sons car and the subs he pushing ( alpine r type 1242d) coujld be powered by the e1800ed but i dunno if its a quality amp and i dont have enought $ to get him a system like mine but i figured this oen would be fine for like 1200$
i dunno though because im comparing it to 2 JL w7 13' with a orion 5000 watt big boy amp
Username: Velk4425
Post Number: 20
I'd spend the extra money to get the JL amp now. It's top of the line.
cuspid fo life
jl sucks you dont want to spend millions on jl i recomend a cuspid 1600 watts max 4 chaNnel amp, the best amp you can buy, jl will last you maybe a month, cuspid will last at least 5 years, buy it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: G3nocd3
San Jose, Ca USA
Post Number: 148
Cuspid you are 100% wrong. Jl is a perfectly good company with amp that last a long time. And why on earth would you reccommend a 4 channel amp when hes lookin for a sub amp. 4 channel = speakers 2 and 1 = subs. (2 works for speakers ok as well). Dont be so narrow minded. Jl is a perfectly good company even tho they are a lil - alot over priced (depending on amp) compared to other conpanies like xtant and fosgate. Other than that they are fine.
cuspid fo life
JL AUDIO = GEO METRO
CUSPID= SUBARU WRX
BUY CUSPID. PERIOD.
Username: G3nocd3
San Jose, Ca USA
Post Number: 164
watever man. You dont know what you are talking about. Cuspid is a no name brand just like pyle and legacy. They have a 1600 watt amp that uses 2 30 amp fuses. LOL like that would put out 1600 watts. Dont talk without thinking, or you mite make your self look more ignorant than you already have.
Username: Sancho886
El Cajon, CA US
Post Number: 134
im pretty sure hes just joking tim.
Username: G3nocd3
San Jose, Ca USA
Post Number: 166
I bet you hes not. so many n3wbies out there these days.
Username: Basshd
Out of those three, I would also choose the JL 1000/1 for bass duties.
Username: James1115
Wilton, Ct
Post Number: 2839
yeah I would choose the JL also. Hey Tim he has been coming on here for a long time saying the same cr@p he is joking man.
Username: James1115
Wilton, Ct
Post Number: 2840
1000/1
Username: Subfanatic
Walton, Ky
Post Number: 3450
dude no, get that xtant some guy is selling on ehre for 600, that amp is unreal, prolly my favorite cleanest amps
Username: Suleman36
Post Number: 1158
Get the JL on ebay for $600.00 i have seem them go for that.
Username: Avs
Sorry im one of those n3wbies, Tim, cause i have no idea what im talking about, but im just curious. Would one JL 1000/1 be able to push a pair of speakers and a pair of subs? Or would I want to dedicate the 1000/1 to the subs (looking at two ava 12's or 15s) and get a less powerful amp for the speakers?
Username: Alias747
Post Number: 45
The Jl 1000/1 is a mono amp, meaning it is only meant to power subs.
Username: Avs
got it thank you sir! (you have no idea how much that helps me lol!)
Username: Stylnul
Vicky ville, CA US
Post Number: 47
tim, if youre even remotely into car audio you would have gotten the idea that a cuspid amp is a piece of s**t and that mr. "cuspid fo life" is just joking, and that amp comes with one, thats right ONE 15 AMP FUSE
get jl, if you can afford it
Username: G3nocd3
San Jose, Ca USA
Post Number: 171
Man chill. That was like 7 posts ago. Stfu about it and dont get bent. You say i got bent, look at you. Chill.
Username: Illuminator
Post Number: 194
That was just...awesome. That piece of thread should be archived...
...JL is like a fudge popsicle. Creamy and delicious, get it.
Username: Ruckus
Oh
Post Number: 23
I have a RF T10001bd, and if your subs can handle it, mine is putting out 1655W at 1 ohm (or 690W at 4 ohm).... 24db/octave crossover...I think its some quality power, and I got mine for 440...not bad for the power, and I think its a damn clean amp....anyone want to comment, feel free
Username: Vtecpower
Post Number: 19
hang on...
if your son's Alpine Type Rs are the pre-2005 range (i.e. handle 300W RMS a piece) a JL 500/1 would be perfect, it will push them to the limits.
If they're the 2005 range then E1800D or even better 1000/1
Facebook
Shop Related Deals
Directory
