I need help
Username: 98neon
i get so confused with the numbers. So ive started to look at Infinitys and i was interested in a Kappa 693.5i:
Type Coaxial
Elements 3-Way
Function Subwoofer, Tweeter, Mid-Range
Size 6" x 9"
Nominal Power Handling 110 Watt
Powered Non-Powered
Technical Features
Peak Power Handling 330 Watt
Frequency Respond 35 Hz - 22,000 Hz
Sensitivity 90 dB
Impedance 4 ohm
Components
Tweeter Design Dome
Tweeter Size 1.13 "
Woofer Material Poly / Plastic
Surround Material Rubber
Now can someone explain to me how to figure out which amplifier would best fit this speakers. If anyone just knows which amps i should look at let me know. And im not looking for really really expensives amps either
Username: Killer44
Ontario Canada
Post Number: 153
get an amp that puts out about 100x2 rms...
