10w7 or 12w7 running off 500/1 - which is louder/better?
Username: Vtecpower
please heeeelllppp!!!
Username: Vtecpower
bump
Username: Vtecpower
^^ bump bump bump ^^
Username: Matt12490
Post Number: 17
what is bump? i see everyone saying it but i dont know what it means
ThatGuyYouKnow
to bring the post to the top, can u wait any longer than 30min? first of all compare cone size, duh the 12 has more area therfore will HOPEFULLY give you deeper bass, and pls never say the word "BETTER" there isnt better its perfrence.
Doesnt the 10w7 and 12w7 have the same rms?
Im use to that, you know like RE and Adire... no matter what size still same RMS...
Username: Suleman36
Post Number: 1176
The 500/1 will work well with both subs. I whould stick with the 10W7 if you are gonna go sealed but if you go ported then go with the 12w7 as its more efficiant ported and louder and deeper especially if you listen to rap. I whould go with either setup.
The 10W7 is 500 watts rms
The 12W7 is 750 watts rms
Username: Thenoose
Post Number: 76
bump
