New member Username: DemkoPost Number: 8 Registered: Apr-05 | I have a A memphis audio 16-PB1KD amp, I found the specs on memphis site but its listed as 16-PR1KD, but says Power Reference/Power Bass Amps, so it must be the same. The ratings are as follows RMS Power 2ohm - 600 x 1 RMS Power 1ohm - 1000 x 1 what would be a good set of subs to power off this, I was looking for 2 12s, should i look for ones that handle 500rms each and run them at 1ohm? That part confuses me :-\ thx for any input. |
New member Username: DemkoPost Number: 9 Registered: Apr-05 | also, I would need 2 DVC 4ohm subs to wire them down to 1ohm correct? |
Gold Member Username: SubfanaticWalton, Ky Post Number: 3229 Registered: Dec-04 | RockFord Fosgate Punch 3 subs are 500 watts rms and are DVC 4 ohms, but what are you looking for, spl or sq, whats your budget for both subs |
New member Username: DemkoPost Number: 10 Registered: Apr-05 | SPL, and I am looking to invest about 400 +/- 100. Thats both subs and a box. But 2 DVC 4 ohms can be wired down to 1ohm right? |
Bronze Member Username: Car_bangsPost Number: 14 Registered: May-05 | 4+4=2 4+4=2 2 and 2 is 1 YES |
Bronze Member Username: Car_bangsPost Number: 15 Registered: May-05 | REALLY DIVISION |
Bronze Member Username: DemkoPost Number: 11 Registered: Apr-05 | ok thx. |
Bronze Member Username: DemkoPost Number: 12 Registered: Apr-05 | looks like im going to get 2 punch3 12s when i save up the money, with a ported box. its about $700 total on cardomain and crutchfield. |
Bronze Member Username: DemkoPost Number: 13 Registered: Apr-05 | would i need to look at a new alt for this setup? my brother had this amp pushing 2 SVC 10" eclipse subs and he didnt change out his alt, but it did die about 6 months later, not sure if it was due to the system or not. |
Gold Member Username: SubfanaticWalton, Ky Post Number: 3282 Registered: Dec-04 | it depends really on the car and what kind it has already, 1000 watts rms should be alright, but how do u figureits going to be 700 bucks, the box should be 100 or less, and the subs should be like 150 for each, so thats only 400 bucks lol |
Bronze Member Username: DemkoPost Number: 14 Registered: Apr-05 | http://www.cardomain.com/sku/ROCP312D4 250 each sub, and I need dynamat, because my trunk rattles on my 98 monte carlo. So I was adding that in the price. I didnt check ebay for anything yet, but if you know where i can get them for 150 each lemme know |
Bronze Member Username: DemkoPost Number: 15 Registered: Apr-05 | well i didnt find thos on ebay only 10" ones. But i found this http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777%26item%3D5771624141 %26 $120 for 2 kicker comp 400rms each. would that sound about as good as the 2 RF punch3's? |
Silver Member Username: DankmanGranger, Indiana United States Post Number: 142 Registered: Jan-05 | Get the two eclipse aluminum 12's the SW7124 DVC t-4's off www.woofersetc.com they are 209.99 a piece and they handle 450rms, great subs, very loud with awesome SQ. |
Silver Member Username: DankmanGranger, Indiana United States Post Number: 143 Registered: Jan-05 | Or you could buy mine already ported, box built to the specs of the eclipse subs. check out the photos, got the subs back from warranty reconed and new voice coils, gonna sell them and not use them. http://www.sounddomain.com/memberpage/772119 |
68768976078 Unregistered guest | I Have 2 10" earthquake tremors 8ohm subwoofers in a ported box bought as a set not sure of the rms rating though any ideas on a cheap amp for daily use to drive them hard. |
