No remote power wire from head unit
Username: Pphillips21
UK
i have no remote power wire from the back of my head unit and my amp doesnt seem 2 work without what can i do about this??
thanx
UK
i really need sum help here
Username: Sony224422
Deep River, CT US
Post Number: 149
find either a power wire in your fuse box that is on when the accesories turn on, or you can look for the power antenna on your head unit if it has one. And yes, your amp needs the remote to turn on, its what tells it to turn on or off. If you can't find either, you can run a wire to the battery, and to a switch, and from the other post on the switch to your amp. If you use a swicth though, you'll always have power to your amp whether the cars on or off so you'll have to make sure your switch is off when the car is off.
UK
what voltage do u need for it 2 work??
mattjk88
So you can just replicate a remote turn on signal with a 12v power supply?
Deep River, CT US
Post Number: 151
all the voltage in the car is the same. and yea you can just replicate one.
Username: Buchanan
you could just connect the remote wire to your speakers in the front or back. as long as they are off when the ignition is switched off. thats what i am going to do on mine because i dont have a remote power wire in my head unit.
