SojiaRaggs9000 Kurk Unregistered guest | Hi i got four 15 inch Kicker Comp 03C15 Component Subwoofer, 4 Ohms. the specs are as follows: * Size: 15", 38.1cm * Impedance: 4ohms * Maximum Amplifier Power: 250Watts RMS/ 500Watts Peak * Sensitivity (dB 1W/1M): 89.2 * Frequency Response: 25-500Hz * Mounting Depth: 7 1/8", 18.1cm * Mounting Hole Diameter: 13 11/16", 34.8cm * Min Rec Sealed Box Vol: 2.25 cu. ft, 63.7 liters * Max Rec Sealed Box Vol: 5 cu. ft, 141.5 liters * Min Rec Vented Box Vol: 3 cu. ft, 84.9 liters * Max Rec Vented Box Vol: 4 cu. ft, 113.2 liters I'm thinking about getting two BOSS PD-4000 amps its 500x2 at 4 ohms what do u guys think? The price of the amp doesn't matter, I'm just trying to get an idea of what to buy.... I kinda know about subs n all that but not really that why I'd really be grateful for the help.... Thanks.... |
sojiaraggs9000 Unregistered guest | ahhh... this is a bs site no one will hit me up with suggestions |
Silver Member Username: JoebruceKY U.S.A. Post Number: 219 Registered: May-04 | Look at jbl or mtx. I always like matching kickers subs with jbl amps for some reason,I dont know why. |
Bronze Member Username: ChungyAustralia Post Number: 21 Registered: Apr-05 | MTX amps are going off cheap as their new ones are out this 2005. JBL like twiztid is pretty good too, bang for bucks like most say. just depends on your preference now. Also which of the 2 brands has a higher resell value just in case you might rid off em some time in the future. good luck dude |
Bronze Member Username: Xtant1001Post Number: 16 Registered: Apr-05 | Selling XTANT 1001 amp normal 1200.00 selling for 600.00 mint condition. call (425) 985-5415 or email unan0@hotmail.com |
