Kappas vs boston acoustics
Username: Thenoose
Post Number: 36
which company makes a better full range speaker
Username: Rob315
Cuse, NY U.S.
Post Number: 427
Boston Accoustics IMO
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 254
boston gets my vote too
Username: James1115
Wilton, Ct
Post Number: 2220
well it depends on the model of the speakers. Boston has a low end line that wouls not par up with the Kappa's but the upper end boston line's such as the pro's and the z's are much much better then the Kappas.
Username: Jonathan_f
GA USA
Post Number: 3639
Totally dependant on what you're referring to. I'm not as big a fan of the newer Pros or the Rallys, the Z series is mainly what I'd consider. Infinity has good stuff for the money.
dave21
how do the infinity kappa perfects component compare with the boston pros component? which is better more clearer, overall???
Username: Nitescort
Post Number: 53
well i heard the Z6s and I have to say they sounded terrible and im a BA fan. now they had the tweeter mounted directly above the mid-bass driver so that could influence the sound but the ones i heard sounded so bad that i cant believe that the placement accounted for all of it. Id go with the DIAMOND HEX series over the BA PROs. same basic price and to me the diamonds sounded distinctly better.
GA USA
Post Number: 3645
They're optimized for off axis performance, they sound better in a car. I don't like their newer stuff as much as the old Pros and such, but it's still ok. I like the Perfects better than the Pros, but both are on the bright side.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 232
I would go with Perfects too..
