Bluejays99 Unregistered guest | I am either going to get a 2 12 W3v2 with a 500/1 amp or 1 12 w6v2. But I don't know what amp to get with the w6v2. What amp do you guys recommend and which setup would you go with? |
Gold Member Username: JmloughreyFarmington, CT Post Number: 1086 Registered: Jul-04 | ...not much money...your amp alone is worth as much as my whole system....unfortunatly i bet mines better ![]() |
Silver Member Username: Rds11Louisville, Kentucky Post Number: 179 Registered: Nov-04 | same amp for the W6v2. It would match up perfectly. the amp was made for that sub. thats tough but if you get that amp then i would take the W6v2 but thats my opinion. |
New member Username: TrmclarenPost Number: 2 Registered: Mar-05 | hey i have 2 polk audio 12inch gnx124 subs and they sound great.i bought these at circuit city for 110$ plus the box.The box came free with the subs.maybe this might help with your money problems |
bluejays99 Unregistered guest | Would this box work for the W6v2? http://www.subzoneusa.com/hs-12v.htm |
nick_sq Unregistered guest | yes |
