Adding new amp with a factory amp already in it...
Username: Dpaw20
FL USA
Post Number: 40
Im adding a sub mono amp for my 2 subs in my Jeep Grand Cherokee. The car came with an Infinity Gold sound system with a 180 watt 6 channel amp. I basically know how to install an amp, but Im confused about adding an amp when I already have one. Im also adding a new HU with 2 preouts and a subwoofer preout. How would I wire the two amps RCA and remote wires, or anything else? A drawing from paint or somthing would be great if anyone could help.
Username: Dpaw20
FL USA
Post Number: 41
anyone?
Username: Subfanatic
Walton, Ky
Post Number: 1371
if i remember correctly, on my new Hu there is two rca jacks in the back and i guess you could just plug in your second set in there, and ive heard people say they just resplice your remote wire
Username: Dpaw20
FL USA
Post Number: 42
ok thx. I was just hoping it wouldnt be anything complicated
Walton, Ky
Post Number: 1376
i oculd be wrong lol
Username: Jmloughrey
Farmington, CT
Post Number: 1034
...i know when my friend installed a new headunit in his volvo that they had to wire around the factory amp....
Username: Steelheadgoof
Fairfield, California US
If you want to use your factory amp along with your mono, attach the rca cables from the factory amp to the hu. If you are running a 6 speaker system use the closest speakers to the front on the factory amp, and rig the rears on the rears channels on the onboard hu amp. Personally I think you are better off buying a bypass kit, and an aftermarket four channel amp.
