Bridging
Shaw
How many subs can be bridged off a mono amp?
Username: Jmloughrey
Farmington, CT
Post Number: 1032
...as many as the ohm load will allow the amp to run at....if you're bridging like say 3 subs and you get a 1.33 ohm load on a 2 ohm stable amp...your gonna have problems...as long as the powers there then go for it...
Username: Fishy
TamaracFt.Laud, FL USA
Post Number: 718
Although only multi channel amps can be "bridged" you can hook up as many as you want as long as the equivalent impedance(series and parallel combos) isn't less than the lowest impedance your amp is stable to. Wiring drivers in series is usually discouraged however.
http://www.jlaudio.com/tutorials/wiring/index.html
-Fishy
