Brown bread vs. dynamat?
Username: Alpineuser
Post Number: 88
according to the specs both give BB isnt that far behind dynamat but on the dynamat site they show it differently. What do u guys think? Ever heard of FatMat it seems to be good to, what should i buy? Keep in mind i need about 75sq ft total for what i have to do.
Username: Jbaker97
Houston, Tx Usa
Post Number: 18
That Fatmat is really thin about 1 mil. I bought 100 sq for about 99 bucks but I had to double it up so I would go with the brown bread.
Username: Geekbike
Post Number: 76
1 mil is 1/1000 of an inch. Fatmat is actually about 45mils and Dynamat is about 70mil.
Username: Jbaker97
Houston, Tx Usa
Post Number: 23
Fatmat is .045" thick whick is 1.035mm and Dynamat extreme is .067" thick which is 1.7mm. Check out their web sites if you dont believe me.
Username: Jbaker97
Houston, Tx Usa
Post Number: 24
That would be some hella thick dynamat ant 45 and 70 mils thick. learn math.
Username: Nnnnick_b
Nc Usa
Post Number: 288
mils and mm are two different measurement. A "mil" is an english unit that is 1/1000 on an inch, a "mm" is a metric unit that is 1/10 of a cm or 1/1000 of a meter. so u are both right.
Username: Subfanatic
Walton, Ky
Post Number: 1203
i would suggest edeadv.1 over that stuff lol
Username: Nnnnick_b
Nc Usa
Post Number: 289
Sell a kidney and get some dynamat extreme.
Walton, Ky
Post Number: 1205
why...
Walton, Ky
Post Number: 1206
http://www.woofersetc.com/product.asp?0=268&1=269&3=741 dynamat 36 square feet is 136 bucks...
you can get 120 square feet of edead for 130 shipped, double it up and it will be better than dynamat extreem...but for the same price as 36 square feet of dyanamaet you can triple it up
Username: Nnnnick_b
Nc Usa
Post Number: 291
i was being sarcastic
Walton, Ky
Post Number: 1208
hhaa i know you were lol...but that stuff is way overpriced....
Username: Fordpwr
Los angeles, Ca Usa
Post Number: 132
just go with that stuff used on roof to waterproof it. its the exact same $hit. you can get a big as$ roll for like 25 bucks. it works great . i double layered my whole expedition(roof,4 doors,rear gate,rear side fenders and fire wall) for under 200 bucks. its one of the most quietest vehicles around
Username: Goon
Post Number: 38
anyone wanna second that? not to say i don't believe you...but i would be more convinced =)
goon
Username: Invain
Michigan United States
Post Number: 1804
Yes that stuff works fine too...
Username: Fishy
TamaracFt.Laud, FL USA
Post Number: 701
If you can find it. I'd like to see a link to that stuff DR MAX. In a previous post it was mentioned that it could be occasionally had at Home Depot, but since its generaly used in northern climes where freezing is a problem I've had no luck finding it down here in Florida, but I still check the roofing section every time I hit the Home Depot just in case.
I can't remember what the stuff is called: "Snow" Seal, Ice Guard or somethin like that.
-Fishy
Username: Fishy
Post Number: 702
Ahh...I remember another handle. I've heard it called "Peel and Seal".
-Fishy
Username: Jmloughrey
Farmington, CT
Post Number: 1022
http://www.sounddomain.com/memberpage/337124/6
Username: Fordpwr
Los angeles, Ca Usa
Post Number: 134
FISHY---i'm pretty sure you can find it at any home depot because its used to waterproof house roofs and it rains pretty much any where. you can also find it at Lows. the brand names will be different but its still the same $hit. its got adhesive on one side, you just peel the plastic film on one side and stick it where you want to. don't waste your money on that other expensive $hit. I've got another roll some where, I just gotta look for it and I'll post the name. It's readily available in 4 diff. sizes, something like 6",12", 2' and 5' rolls( sizes are width). Ask around, you'll find it.
Username: Minime80
Post Number: 103
http://building-materials.gillroys.com/Roofing_materials/Roll_roofing/Eaveguard- s119458.html
looks like good stuff... 60 mil thick.
Username: Goon
Post Number: 41
where do you see that it says it's 60 mil thick? i just see the size of the sheets.
Username: Minime80
Post Number: 114
right here
http://www.henry.com/datasheets/Henry_Eaveguard_TDS.pdf
Username: Goon
Post Number: 42
ahh i see now...so this works just as well as other things?
Username: Minime80
Post Number: 116
For the price you could triple layer it cheaper than you could single layer it with the other stuff, and that would be WAY better than those others... heck, even double layer (which is probably plenty) should be better than a single layer of the others.
Post Number: 108
is that 3" x 33' or 3' x 33'. if its only 3" x 33' thats only like 8 sq.ft
Username: Minime80
Post Number: 119
It's 100 square feet total so 3 feet by 33 feet
Username: Minime80
Post Number: 120
Hey, someone else has used it and it looks like it works great!
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=3;t=022980
Walton, Ky
Post Number: 1334
how much would 100 square feet cost
Username: Minime80
Post Number: 121
looks like $29.49 for a 100 sq. ft. roll, I'm gettin' me some.
Walton, Ky
Post Number: 1341
wow...thats a good price
Username: Jwbulger79
Florida
Post Number: 313
dude. that's crazy. it looks like its the same stuff as Peel-n-Seal. the only reason i didnt get that was b/c i could get eDead cheaper. eDead v1 and peel-n-seal is only 45mils thick, too. here's alink for peel-n-seal - $90 + $14.50 shipping
http://www.abccatalog.com/store/viewitem.asp?idproduct=2579950436
i read a lot of great reviews by people who used that in their vehicles, and like i said, the only reason i didnt get it was teh eDead was slightly cheaper. we need to find out more about the Everguard stuff. if it's the same as peel-n-seal, i'm getting 200sq ft for my 4runner!!
what kind of backing is on it? is it aluminum like everything else?
Username: Minime
Portland, OR
I just ordered a 100 sq. ft. roll so I'll tell ya'll what it's like when it comes.
Florida
Post Number: 315
i started a new thread for Eaveguard in the accessory section. things dont move so fast over there.
https://www.ecoustics.com/electronics/forum/car-audio/128284.html
